AutoCAD 2010/2011/2012
klgwhite
Message 1 of 12 (8,319 Views)
AEC object error messages
8319 Views, 11 Replies
10-18-2012 05:42 PM
I'm working in AutoCAD 2010 and have just recently begun getting the following errors when opening any file.  Even files that I have created from scratch in the same version of CAD.
This is the error I get when I open the file:
"To be fully compatible with this version, save the drawing from the original application as AutoCAD 2000/2004/2007/2010 format with AEC objects exploded or with Proxy Graphics enabled"
Then, when I try to copy/paste from the menu bar (as opposed to just "c" from the keyboard or icon), I get this error:
"This application has detected a mixed version of AEC objects participating in this operation.  Newer AEC objects will be disallowed from participating in this operation"
It happens even when it's just lines - no objects at all.
What is going on, and how do I fix it?  Thanks!
pendean
Message 2 of 12 (8,287 Views)
Re: AEC object error messages
10-19-2012 06:36 AM in reply to: klgwhite
Did you recently experiment with R2013? If not, someone else did with all of these files and now all the AEC content has been upgraded and taken out of your 2010 version's control. Or you keep dragging content (or using a template file) saved down from R2013.
If you don't these AEC objects, -EXPORTTOAUTOCAD command (there is a dash in the command name) in 2013 can get rid of them for you. It may work in 2010, but I've not had good luck with it myself.
There is no other fix, unless you want to go ahead, pony-up, and upgrade to R2013 today.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
klgwhite
Message 3 of 12 (8,283 Views)
10-19-2012 06:50 AM in reply to: pendean
It started happening after I opened a file from a consultant, so yes, that's a possibility, but the other files are mine, created by me, and never opened or edited by anyone else.  That's what has me confused - it's doing it with every file - even ones that I haven't opened in months.
So, if I'm not ready to upgrade to 2013, I just keep hitting "accept" or "ok" and ignore the errors?
pendean
Message 4 of 12 (8,280 Views)
10-19-2012 07:17 AM in reply to: klgwhite
In my first reply, second paragraph, is a fix if that works for you and your consultants: talk to each other and decide what's best.
Existing files don't suddenly become laced with AEC content on their own: you or someone introduced them in the file(s) with a copy/paste or INSERT or XREF or more.
Distinguished Contributor
timsparks6941
Message 5 of 12 (4,889 Views)
11-07-2013 06:54 AM in reply to: klgwhite
Is there a way to suppress the error dialog box?
pendean
Message 6 of 12 (4,876 Views)
11-07-2013 09:51 AM in reply to: timsparks6941
Which one?
timsparks6941
Message 7 of 12 (4,875 Views)
11-07-2013 09:55 AM in reply to: klgwhite
pendean
Message 8 of 12 (4,846 Views)
11-07-2013 12:58 PM in reply to: timsparks6941
No cure if you always save the file down lower than 2010 format but should go away after the first time you open an older file if you save to 2010 format (and stay there).
To permanently fix it you must get rid of / explode the AEC content.
timsparks6941
Message 9 of 12 (4,844 Views)
11-07-2013 01:00 PM in reply to: klgwhite
I noticed in the 2013 convertor that there is an explode AEC objects selection.  I guess that is what you are talking about?  Once exploded it's a matter of selecting the entity type and deleting them?
pendean
Message 10 of 12 (4,834 Views)
11-07-2013 05:40 PM in reply to: timsparks6941
-EXPORTTOAUTOCAD command (there is a dash in the name): it may work and worth trying. Works best if you knock the file down to the lowest format allowed.
