AutoCAD 2010/2011/2012
New Member
0 Kudos
Post 1 of 5
Adjusting transpareny of Text.
177 Views, 4 Replies
02-23-2010 09:47 AM
Hello All,
I'm new to AutoCAD (so, I'm sorry if this question has been asked before!) ... but how can I adjust the transparency of text?
e.g. I wish to place 'for discussion only' across the drawing in a large pt size, but still be able to read what is beneath the text.
Any ideas?
*Expert Elite*
594 Kudos
Post 2 of 5
Re: Adjusting transpareny of Text.
02-23-2010 09:51 AM in reply to: PaulTowle8306
Make it a gray color with percent of fade in the CTB file and in the plotter set lines to merge.
New Member
0 Kudos
Post 3 of 5
02-24-2010 09:02 AM in reply to: PaulTowle8306
Thanks for the reply, but does this also make the text transparent on screen?
(it needs to be transparent on the screen too!)
*Dean Saadallah
Post 4 of 5
02-24-2010 09:11 AM in reply to: PaulTowle8306
Whatever gray color works for your screen, you can assign that.
Dean Saadallah
http://LTisACAD.blogspot.com
*Expert Elite*
594 Kudos
Post 5 of 5
02-24-2010 09:20 AM in reply to: PaulTowle8306
You could make that text an xref and fade it in the OPTIONS, that way it's in the background and you can see important entities.
Post to the Community
New Post
