hi guys,
I just have an Issue about AutoCad 2012. i've used it yesterday but when i'm opening it today, it give me this error:
FATAL ERROR: Unhandled Delayload "AdApplicationFrame.dll" Module Not Found Exception at fd7e9e5dh.
I try also to re-install the Microsoft Net4 Framework. but still the same error appear.
thanks!
Some people have had luck ripping out the .NET completely and reinstalling the full 4.0 redistributable. I was thinking I recall this being a problem if you had the old AutoCAD 2011 version installed because the .NET provided was problematic. Might at least be worth a shot.
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
