AutoCAD 2010/2011/2012
Valued Contributor
Kycau
Message 1 of 6 (679 Views)
acad.pgp
679 Views, 5 Replies
06-21-2013 01:05 AM
In the acad.pgp file ("Tools" > "Customize" > "Edit Program Parameters (acad.pgp)" ), there are several lists of command alias, and each list contains alias...
Have a look at these two lists from my acad.pgp:
;  -- Sample aliases for AutoCAD commands --
D,         *DIMSTYLE
;  -- User Defined Command Aliases --
D,         *DIMLINEAR
so, you see, I have the same alias for two commands... Correct me if I am wrong, but as far as I understand, the alias from ";  -- User Defined Command Aliases --" just have the highest priority in the acad.pgp. Am I right ?
This way, I can edit the ";  -- User Defined Command Aliases --" alias list in the Notepad, without bothering myself, if this alias is already used in the ";  -- Sample aliases for AutoCAD commands --  ". Is this so ?)
*Expert Elite*
pendean
Message 2 of 6 (669 Views)
Re: acad.pgp
06-21-2013 05:36 AM in reply to: Kycau
AutoCAD will read the last entry it finds: so if D=Dimlinear is at the bottom of the ACAD.PGP file that is what D will get assigned to. That's why the user defined section is at the bottom.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Valued Contributor
Kycau
Message 3 of 6 (664 Views)
Re: acad.pgp
06-21-2013 06:05 AM in reply to: pendean
thx )
now I know exactly how it works
Valued Contributor
Kycau
Message 4 of 6 (663 Views)
Re: acad.pgp
06-21-2013 06:08 AM in reply to: Kycau
What does
; Aliases for commands discontinued in AutoCAD 2004:
mean ?
That in AutoCAD 2009 o earlier these alias will not work ?
cause I use AutoCAD 2011, and at least one command from the list works (BMOD, *BLOCK).
*Expert Elite*
pendean
Message 5 of 6 (648 Views)
Re: acad.pgp
06-21-2013 09:37 AM in reply to: Kycau
Someone at Autodesk decided to mask dead commands with other current/available commands to help those users that may not know it.
Valued Contributor
Kycau
Message 6 of 6 (645 Views)
Re: acad.pgp
06-21-2013 10:56 AM in reply to: pendean
so that's the point, that ALL of them work in AutoCAD 2011...
For exemple:
; Aliases for commands discontinued in AutoCAD 2000:
DDATTDEF,   *ATTDEF
ATT,       *ATTDEF
both of them work properly in my AutoCAD 2011 :smileyhappy:
English is not my native language, but "; Aliases for commands discontinued in AutoCAD 2000:" I would understand as if they don't work in Autocad 2000+ versions.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
