AutoCAD 2010/2011/2012
*Expert Elite*
rkmcswain
Message 11 of 14 (163 Views)
Re: acad pgp not working
04-30-2012 06:55 AM in reply to: mani_mreza
mani_mreza wrote:
Hurrrrrrrrrrrrrrrrrrra
thank you very much!
now it's over. i found two acad.lsp, one in FONTS directory and one in Acad root. i've removed both and now the pgp file works. that was a great help. thank you very much.:smileyvery-happy:
As you have found out, lisp definitions override those in the PGP file. This can be of use, because there is only so much you can do with PGP shortcuts. If you need to create a shortcut key that does more than launch a command, you will want to use autolisp and place it in "ACADDOC.LSP" (not "Acad.lsp").
Active Member
mani_mreza
Message 12 of 14 (154 Views)
04-30-2012 09:57 AM in reply to: rkmcswain
thanks for reply and useful informations. As an architect i'm not familiar with AutoLisp and lisp creating. But when command shortcuts are changed i will become really confused.
*Expert Elite*
rkmcswain
Message 13 of 14 (148 Views)
04-30-2012 11:17 AM in reply to: mani_mreza
If you're interested, here is a quick example. Don't let the "autolisp" term turn you off. Look at it like scripting.
Add this to your existing (or new if it doesn't exist) file named "ACADDOC.LSP", and make sure it's located in your support file search path. Then close and relaunch AutoCAD. There will be a command named ZD, and it will perform a Zoom Dynamic.
(defun c:zd ()
 (command "._zoom" "_D")
New Member
qpuser
Message 14 of 14 (5 Views)
09-14-2014 03:26 AM in reply to: mani_mreza
We too had the same issue with some users.  Just copy the acad.pgp file from the working user to the problem PC and replace the file.
Regards, Tony Mathews.
Need installation help?
