AutoCAD 2010/2011/2012
Valued Contributor
milton.fitzgerald
Message 1 of 7 (8,983 Views)
acad.lsp showing up in drawing files folders
8983 Views, 6 Replies
12-05-2012 09:21 AM
Does anyone know why I'm getting "acad.lsp" files (approximately 27 to 28 KB) showing up in my drawing files folders?
I'm not sure but I thought this file was suppose to be in the
Program Files\Autodesk\*.*, folder?
I seem to be multple copies of this file.
As usual, any information or help would be appreciated.
Milt Fitzgerald (a.k.a. Drafter1981)
Siemens Industries (Full-Time Office Position)
Fitz’ Digital Cad Service L.L.C. (Consulting Business)
https://sites.google.com/site/fitzdigitalcadservice/
Hi Milt,
Current up-to-date antivirus programs should be able to find and remove all known AutoCAD viruses, unless there is a brand new one that hasn't been cataloged yet.
You should do a full scan of all files on all hard drives, which I think may not be how an antivirus program is setup by default, or it is a manual action that you need to take. You may also do a manual file search for acad.lsp and acaddoc.lsp files and delete them.
We have these articles on our web site about viruses:
http://usa.autodesk.com/getdoc/id=TS1103867
http://usa.autodesk.com/getdoc/id=TS19860569
http://usa.autodesk.com/getdoc/id=TS13717811
Some of these have links at the bottom to additional articles.
Valued Contributor
Patchy
Message 2 of 7 (8,970 Views)
Re: acad.lsp showing up in drawing files folders
12-05-2012 09:42 AM in reply to: milton.fitzgerald
ACAD.LSP virus has been around for a long time.
Search Autodesk site, there is a way to remove it.
Valued Contributor
milton.fitzgerald
Message 3 of 7 (8,966 Views)
12-05-2012 09:56 AM in reply to: milton.fitzgerald
Thanks for the response... I probably should rephrase the question as
"How do you know the difference between the acad.lsp virus and a legitimate acad.lsp files?"
Valued Contributor
Patchy
Message 4 of 7 (8,915 Views)
12-06-2012 06:55 AM in reply to: milton.fitzgerald
The fake ones show up outside of Support Files Search Path that when you installed Autocad and they don't have acad+a number as shown in the 1st post.
Product Support
bryce.thelin
Message 5 of 7 (8,881 Views)
12-07-2012 02:49 PM in reply to: milton.fitzgerald
Hi Milt,
Bryce Thelin
Valued Contributor
milton.fitzgerald
Message 6 of 7 (8,708 Views)
01-21-2013 03:08 PM in reply to: bryce.thelin
To this date there has been "No Real Resolution". The only response that was close was from Bryce Thelin.
Also as I have discovered depending upon the version of AutoCAD, or the settings that you may have in regards to loading Autolisp. Early versions such as Acad2008, would ask you in the settings (systems tab, of the options dialog box), under General Option if you wanted to Load acad.lsp with every drawing. And of course the main ACAD.LSP  file remained in the folder (C:\Program Files\AutoCAD\Support). Now with the newer versions of AutoCAD,  it seems as if you don't have the right settings, or if some "glitch" occurs you are unable to tell if the acad.lsp file is a virus, or actually required as a setting for the drawing file that you may be working on.
Active Member
martinaitken5856
Message 7 of 7 (7,984 Views)
03-12-2013 04:12 PM in reply to: milton.fitzgerald
I have had this virus pop-up on our systems a few times and I would add this to Bryce's advice:-
1. The virus is self-editing so inserts blank lines to fool virus scanners. Very rarely did our corporate scanner find it;
2. I have replaced the ACAD.LSP and ACADDOC.LSP with a blank file and made it read-only and a hidden file so the virus cannot change it (unless you get a variant that can!!)
We have been virus free for a few months now since our last clean up so hopefully this has worked :smileywink:
