AutoCAD 2010/2011/2012
Distinguished Contributor
2 Kudos
Post 1 of 6
[ 3DModeling ] GRIP Problem!
572 Views, 5 Replies
07-28-2010 11:21 AM
I've been 3d modeling since AutoCAD 2005, and recently I noticed something very inconvenient.
If an object (Object A) is behind another object (OBJECT B), then the 3D Solid grips that should appear on OBJECT A get hidden, forcing me to change my view shade (VSCURRENT) to wire frame in order to access those hidden grips.
Is there a system variable which would allow me to view those grips like I would in the wireframe?
I attached two images.
I want to see ALL those grips which are visible in the wireframe mode the same in the shaded(Realistic/Conceptual etc.) mode.
Thanks in advance.
Active Contributor
2 Kudos
Post 2 of 6
Re: [ 3DModeling ] GRIP Problem!
07-28-2010 12:00 PM in reply to: oyy5408
just out of curiosity, is this something that you were able to do before 2011? try reading here >http://docs.autodesk.com/ACD/2011/ENU/filesACR/WS1a9193826455f5ffff8c2a10d68757bb5-7e69.htm <
let us know if that helps :smileyhappy:
2 Kudos
Post 3 of 6
07-28-2010 01:58 PM in reply to: oyy5408
Yup I think this feature disappeared since 2009. NOT 100% sure though.
System variable 3DSELECTIONMODE did not solve the issue.
I would TRULY love to have this feature back.
Active Contributor
2 Kudos
Post 4 of 6
07-28-2010 02:28 PM in reply to: oyy5408
2 Kudos
Post 5 of 6
07-28-2010 04:57 PM in reply to: randomnewb
THANK YOU!
CAN I WORSIP YOU?? OH MAN THANKS!
20 Kudos
Post 6 of 6
05-08-2012 10:02 AM in reply to: oyy5408
Wow, thanks a lot too!:smileyvery-happy:
