AutoCAD 2010/2011/2012
Valued Contributor
rmckee
Message 11 of 18 (366 Views)
Re: 2012 PDF's crash system
08-26-2011 09:18 AM in reply to: PETEWERRIN3578
The fact that PDFs regenerate so slowly makes them inefficient in our environment. If they are bitonal, we convert the PDFs to TIFS and attach the TIF files. If they are multitonal, we convert to JPG and attach. This substantially speeds up regeneration time without a substantial decrease in quality. However, you do get rid of the PDF enhanced functions such as being able to do snap points, but our images are generally reference only type information. Anyways, food for thought.
Valued Mentor
TrevN
Message 12 of 18 (347 Views)
08-29-2011 11:58 PM in reply to: rmckee
Well using 32bit with 2012 could well be the problem.
AC is now so power hungry it's mad, and I wouldn't even consider using it on anything less than 64bit.
2011 was bad enough for crashes due to lack of memory, I can't imagine what 2012 is like. I's switch to 64bit and I'd be surprised if the same problem occured, but that's easier said than done!
Member
kim.jackson
Message 13 of 18 (337 Views)
08-30-2011 06:22 AM in reply to: TrevN
Actually, one of our IT guys was able to produce the same problem and he has a 64-bit machine.  We are thinking it is a bug but who knows.
Thanks for replying.
Valued Mentor
TrevN
Message 14 of 18 (333 Views)
08-30-2011 06:35 AM in reply to: kim.jackson
2012 on 64 bit isn't perfect, and if it's been running for several hours it still uses alot of memory and only clears if you start a new session.
2012 on 32 bit, no thanks!
Member
kim.jackson
Message 15 of 18 (331 Views)
08-30-2011 06:38 AM in reply to: TrevN
I agree!  However, try to explain to non-engineer, non-CADD upper management that we need higher end machines that are capable of running more than Microsoft Office!  I'm sure you've never experienced that <<sarcasm>>.  :smileywink:
Valued Mentor
TrevN
Message 16 of 18 (329 Views)
08-30-2011 06:41 AM in reply to: kim.jackson
Never, nor the need to dual monitors, or to have admin rights to machines, or..... where would you like to to end?!!!!!!
Product Support
luconceicao
Message 17 of 18 (321 Views)
08-30-2011 07:39 AM in reply to: PETEWERRIN3578
Are you creating the PDF files with DWG To PDF.pc3?
We could try to reproduce the issue if you send the files.
Please use eTransmit to pack all the needed files, then explain in detail the settings to create the PDF.
Cheers,
Luciane
Luciane Conceicao
Product Support Specialist
New Member
simon.foster
Message 18 of 18 (67 Views)
10-21-2013 02:05 AM in reply to: PETEWERRIN3578
I am also having this issue...  My Spec is good too.. Windows 7, Intel(R) Xeon (R) CPU W5590 @3.33GHz (2 Processors) 18.0GB RAM, 64-bit Operating System, NVIA Quadro FX5800...  Best way is to place the PDF on a layer that OFF.
