Here is the thing. I have 2007student Lt on an xp computer. Bought a new computer & 2012 Lt. I was very happy with the 2007. Can I do something to 2012 Lt to make it run like 2007? I am having a rough time using 2012. I don't need or want the extra bells. HELP
Solved by rkmcswain. Go to Solution.
What parts exactly? Most new things can be disabled.
The link below points to a good reference. It's for AutoCAD, so some things may not apply. See the other links at the top of that page also.
http://www.blog.cadnauseam.com/2011/04/14/autocad-2012-putting-things-back-to-normal/
I would like nothing better than to have 2012 act like 2007. I know that sounds like I'm not right upstairs but I'm 75 and was happy with what I had. This new one is a mess to me. Don't know what a ribbon is.
I will look at the page you recommended. I really would like to know what files I can copy from 2007 & stick them in 2012. I wolder if autodesk would swap licences with me. They can take back 2012 & give me 2007.
Yes, you are right. My problem is the last time I had an admin do the setup for the office & I used the system. I got a lot of help from a blog that was listed. Thanks for trying to help.
