AutoCAD 2007/2008/2009
Distinguished Contributor
Kiwi Russ.
Message 1 of 15 (295 Views)
Z value with "CHSPACE"
295 Views, 14 Replies
08-04-2008 02:11 PM
Why when I use CHSPACE command do I get a z value added to an entity either going from paperspace or from model space?
What causes this and how can I stop this?
kingtut
Message 2 of 15 (295 Views)
Re: Z value with "CHSPACE"
08-04-2008 02:21 PM in reply to: Kiwi Russ.
Are you LDD user?
Kiwi Russ.
Message 3 of 15 (295 Views)
08-04-2008 04:22 PM in reply to: Kiwi Russ.
No I have vanilla Autocad 2007
*Dean Saadallah
Message 4 of 15 (295 Views)
08-05-2008 04:48 AM in reply to: Kiwi Russ.
Cannot replicate: you got a sample that does this?
Dean Saadallah
http://LTisACAD.blogspot.com
Add-on products for LT
http://www.pendean.com/lt
kingtut
Message 5 of 15 (295 Views)
08-05-2008 06:24 AM in reply to: Kiwi Russ.
Hope someone could figure why when draw anything in layout and use chspace it put z elevations after it moved to Modelspace.
bob.at
Message 6 of 15 (295 Views)
08-05-2008 08:03 AM in reply to: Kiwi Russ.
A first guess: it comes form sysvar BACKZ, wich is set to -234.987 in your
drawing. No idea why and for what reason chspace depends on the setting of
BACKZ, wich holds the value for the back clipping plane in DVIEW
bob.at
CAD & GIS Services, Graz, Austria
schrieb im Newsbeitrag news:5998477@discussion.autodesk.com...
Hope someone could figure why when draw anything in layout and use chs it
kingtut
Message 7 of 15 (295 Views)
08-05-2008 08:05 AM in reply to: Kiwi Russ.
That was the problem when I checked the drawing variables.
It was read only.
:smileysad:
Kiwi Russ.
Message 8 of 15 (295 Views)
08-05-2008 06:35 PM in reply to: Kiwi Russ.
kingtut are you hijacking my post?
You are confusing the forum!!
Here is a sample drawing showing the problem I have. If you try using CHSPACE to bring a line from model space into paperspace and vice versa you will find a z value added.
You will find BACKZ is set to 0.
Russ
kingtut
Message 9 of 15 (295 Views)
08-05-2008 08:13 PM in reply to: Kiwi Russ.
Sorry bud, Dean wants to test it out. Are you mad?
bob.at
Message 10 of 15 (295 Views)
08-06-2008 12:46 AM in reply to: Kiwi Russ.
Here it is maybe the z value of TARGET ?!?
bob.at
schrieb im Newsbeitrag news:5999254@discussion.autodesk.com...
Russ
Announcements
Need installation help?
