In the External References box. there is no option to "Attach PDF". It only shows "Attach DWG", "Attach Image", "Attach DWF", "Attach DGN". Does this mean there is a file I am missing? Please help
Solved by ukdxb012. Go to Solution.
Hello
Welcome to the Autodesk/AutoCAD Forums !
A quick idea : Maybe you could print/plot your PDF as an Image JPG !?
... and then you can insert the JPG (with your ACAD 20xx) !
Patrice BRAUD
