AutoCAD 2009 SP3
My user has a drawing. When he checks markups through the Markup Set Manager (Ctrl + 7) and starts "Republish Markup Sheets", AutoCAD doesn't ask the DWF file name for publish result. And result are located in the ..\ (i.e. parrent directory) always. It is very inconvenient.
But all other DWG files has not such problem: AutoCAD asks the DWF file name for each of the publish operation through the "Specify DWF file window".
How can I correct it?
Thank you.
