AutoCAD 2007/2008/2009
Distinguished Contributor
wsargent
Message 1 of 9 (3,440 Views)
Update inserted Blocks?
3440 Views, 8 Replies
11-01-2010 01:36 PM
I have a drawing withe 130+ blocks that have a Attribute Definition (text) in them that the customer does not like the font that I chose. I have changed the font in the block editor, but none of the blocks are showing the update. Is there a way for the existing blocks to 'refresh' to reflect the font change?
Thanks in advance.
__________
AutoCAD Civil 3D 2012 (Primary), 2011 by contract.
Dell Percision T3500: MS Windows 7 64-bit SP1; Intel Xeon CPU W3505 @ 2.53GHz, 12.00 GB RAM, NVIDIA Quadro 600
Distinguished Mentor
tschau3
Message 2 of 9 (3,439 Views)
Re: Update inserted Blocks?
11-01-2010 01:49 PM in reply to: wsargent
ATTSYNC command?
wsargent
Message 3 of 9 (3,437 Views)
11-01-2010 01:51 PM in reply to: tschau3
Thank you!
__________
Member
jadvimpolininkas
Message 4 of 9 (3,064 Views)
07-19-2012 04:12 AM in reply to: wsargent
Hi, i write in this topic because my question regards inserted block update.
The situation:
I create a block in my drawing
several people modifies copies of that drawing at the same time, also modifies the blocks i have created in that drawing.
finally i need to bring all modifications the others have made back to one file.
Problem:
When i insert modified blocks back in to my drawing all modifications resets back to the beginning state.
is there a way to setup autocad to behave this way: when i insert updated block, all of the blocks with the same name  updates according to the inserted block. i am copy pasting multiple blocks at the same time so i need a simple solution.
Thanx in advance.
Mantas.
Alfred.NESWADBA
Message 5 of 9 (3,062 Views)
07-19-2012 04:27 AM in reply to: jadvimpolininkas
Open your drawing where your want to update the blockdefinition.
Then start designcenter, navigate to the drawing where the block is stored like you want to have it as final result, look into the list of blockdefinitions and right.click onto the block that has to be used for update and ..... :smileywink:
- alfred -
Alfred NESWADBA
Member
jadvimpolininkas
Message 6 of 9 (3,061 Views)
07-19-2012 04:42 AM in reply to: Alfred.NESWADBA
thank you for informative and quick reply.
could you give me some links how to use designcenter?,
Can i use it with Autocad 2006, is it standalone product or part of autocad?
thanx.
wsargent
Message 7 of 9 (3,057 Views)
07-19-2012 05:19 AM in reply to: wsargent
The design center is part of AutoCAD. I have not used 2006 in some time but I believe that it was part of the program then. The command to activate the pallet is ADCENTER, and there should be a button on the standard tool bar that also opens it.
__________
Member
jadvimpolininkas
Message 8 of 9 (3,054 Views)
07-19-2012 05:33 AM in reply to: wsargent
Thank you, i will try that.
scot-65
Message 9 of 9 (3,048 Views)
07-19-2012 04:05 PM in reply to: jadvimpolininkas
Sounds like you may need a little block management scolding.
For those that "BEDIT" your original blocks, have them WBLOCK these
to a central folder where each station has a support path to that folder.
From there you can use the command line -INSERT and enter BLOCK1=BLOCK1.
I have heard you can even use "BLOCK1=" without calling the second name.
You can also use BLOCK1=BLOCK2.
I believe you can use the dialog INSERT, but you have to point to the file in the folder
in order for an alert type dialog to appear that warns you the block will be redefined.
If you select from the list box, you will not be redefining the block (it acts like COPY).
Your other alternative is to explode or erase all definitions of the block, then PURGE
the block name, finally INSERT the revised block of same name.
Another method is to explode the "NEW" block, copy with base point, then paste as block.
The use of XREF is still yet another method to consider.
The ultimate solution would be if one needs to edit the block, do not BEDIT.
Instead, open the block in a separate editing session, make the changes, save, and close.
Then do the above steps or use my little program below...
With that said, here is a program that will allow you to select an existing block
on the viewing screen, and the block definition will be updated based on the first
occurrence of the block's name in the support path (our code panels are moving
targets that are frequently updated).
UPD - Update Blocks. Select an object and the block will be redefined based on the
first occurrence of the block's name in the support path. Copy-clip objects will not
work if you paste them as a block.
If you do not know how to load this program, place file in a central folder and
command APPLOAD, and select the Startup Suite button. Repeat for each station.
Scot-65
Dyslexia is a permanent physical disability that cannot be seen.
Introverts is proof that there is indeed intelligent life on this planet.
