AutoCAD 2007/2008/2009
Active Contributor
trabical
Message 1 of 8 (579 Views)
Unknown command "Externalreferences"
579 Views, 7 Replies
03-31-2008 07:31 AM
For some reason my xref command and functionality is missing. I just installed an update regarding my Cad crashing when opening a large raster image. Whenever I enter the External reference command or even click the button in the toolbar it says "Unknown command "EXTERNALREFERENCES". Press F1 for help". I don't know how long exactly I've had this problem but that update was the only change I have made in a few weeks.
*Dilip Damle
Message 2 of 8 (579 Views)
Re: Unknown command "Externalreferences"
03-31-2008 09:09 AM in reply to: trabical
try
command:._externalreferences"entrer"
or
command:._-xref"enter"
rgds
Dilip Damle
Life will be much easier if we just have a printout of
all the commands that exist in Autocad kept handy.
Member
Klaids
Message 3 of 8 (411 Views)
08-21-2012 11:07 PM in reply to: *Dilip Damle
this same problem, by typing command displays the same Unknown command "Externalreferences"
*Expert Elite*
pendean
Message 4 of 8 (398 Views)
08-22-2012 05:49 AM in reply to: trabical
Do any of the other palette-based commands work?
Are you using the core CUI menu file, or recently change toa  custom one?
Have you tried a repair of R2008? a reinstall?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
Klaids
Message 5 of 8 (390 Views)
08-22-2012 11:01 PM in reply to: pendean
YES
No, original, because I do not know what it is and why do i use custom one.
my Cad crashing when opening a large file or try saving jpg to web and i asked administrators to put more RAM and reinstall AutoCad. After reinstalling still crashing and do not work external refereces. Crashing started some time beck, but not from the start.
My pc spec:
Win7 Enterprise 64bit, CPU-i3-2100, RAM- 8Gb, AutoCad LT 2008 SP1 Version: B.219.0 (UNICODE)
thx for helping
*Expert Elite*
pendean
Message 6 of 8 (374 Views)
08-23-2012 06:08 AM in reply to: Klaids
LT2008 is not supported in Win7: so do you have it installed in Win7's XPMode, or something else?
Autodesk recommended uninstall and reinstall procedures are quite elaborate, share this with your I.T. it may help:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10243968&linkID=9240617
Member
Klaids
Message 7 of 8 (368 Views)
08-24-2012 03:50 AM in reply to: pendean
i show this to I.T. on monday.
now i get new fatal error unhandled delayload acgsimage.dll when try to print :smileysad:
adding some pic of fatall errors.
Member
Klaids
Message 8 of 8 (336 Views)
08-27-2012 04:43 AM in reply to: pendean
After recommended reinstall Externalreferences works again. And i realized thet publish to web jpg crashes when saved to server and do not crashes when saved on pc (need to test ir some more)
How do i mark response as "Accept as Solution" ?
Need installation help?
