Tricks to Make 3D Glasses Quickly
Introduction
www.blog-autocad3dtutorial.blogspot.com - In creating objects in AutoCAD 3D solid model and there are no surface models depending on the image. In this article I will write about Tricks to Make 3D Glasses quickly using Surface models. Where the making of 3D glasses is very simple.
What What is to be Done
Steps By Steps :
1. For the line with the command line as a reference to rotate the object
2. For the line with the Pline command to form a curved arc select or press the letter A and select a straight line or press L
3. Set display mode to 3D via:
- View menu
- Select 3D View
- Specify the options either 3D isometric or others in accordance with your wishes
4. To set the density of lines to look smooth set:
- Type the command surftab1 command and enter the value 20
- Type the command and enter the value 20 surftab2
The greater the value, the more smooth the resulting image
5. To make a 3D object then select:
- Modelling the Draw menu and select
- Select Meshes and choose Revolved Mesh
6 Change the 3D view using the 3D rotate and type 90 Degrees
7 Render type the command to see the final result :
I think it is quite clear what I wrote in the article tricks quickly make 3D glasses with Surface models using AutoCAD 2007 and to more clearly you can see the video tutorial here. Thank you for this article may be useful to readers, especially for those of you who are just learning.
