AutoCAD 2007/2008/2009
Active Member
CHARLIE1983
Message 1 of 6 (192 Views)
Tool Palette problem
192 Views, 5 Replies
05-11-2012 08:16 AM
My docked tool palette has worked for a long time. In the last few days, when I go to pick the
blocks, they are visual in the palette, but I am not able to drag to drawing? Is there some setting
that was changed that does not allow selecting and dropping into drawing?
Alfred.NESWADBA
Message 2 of 6 (185 Views)
Re: Tool Palette problem
05-12-2012 01:42 AM in reply to: CHARLIE1983
when you double click on the icon ... what happens?
when you try to drag&drop ... do you get a message in the command-line?
- alfred -
Alfred NESWADBA
Active Member
CHARLIE1983
Message 3 of 6 (182 Views)
05-12-2012 08:21 AM in reply to: CHARLIE1983
In the command line , it says,  block    " name  "    not found.
Alfred.NESWADBA
Message 4 of 6 (180 Views)
05-12-2012 08:24 AM in reply to: CHARLIE1983
So my first guess is: the drawing, where the block-definitions come from, has been moved or deleted. Behind every block-item in the palette there is defined where to get the block-definition (a DWG-file where this block is defined). If this drawing is not at the location/the folder where it was at the time you defined the palette, this error raise up.
- alfred -
Alfred NESWADBA
Active Member
CHARLIE1983
Message 5 of 6 (179 Views)
05-12-2012 08:29 AM in reply to: Alfred.NESWADBA
Yes, good point, I did rearrange alot of files recently and maybe misplaced. It may take a fews days till I get to this.
I will let you know  how it works out. Thanks.
Ameriplan
Message 6 of 6 (155 Views)
06-11-2012 09:51 AM in reply to: CHARLIE1983
I had the same problem.  I started using the command WBLOCK instead of BLOCK.  The difference is that the command BLOCK creates the block in the drawing that you are working with at the time.  WBLOCK creates a drawing block in the a directory that you specify and with that you can create a tool pallete by using DesignCenter.
