AutoCAD 2007/2008/2009
0 Kudos
Post 1 of 6
Text display quality
111 Views, 5 Replies
10-13-2008 06:01 PM
Text (truetype) when viewed in Model tab look kind of blurred/pixelated, however when viewed in Layout tab looks perfect. Any ideas why?
Thanks.
Geoff Edited by: geoff@cockburn.wa.gov.au on Oct 14, 2008 9:02 AM
*Dean Saadallah
Post 2 of 6
Re: Text display quality
10-14-2008 05:31 AM in reply to: geoffamos
The only time TTF fonts look blurred is when they have a Z height setting
other than zero: fix it (don't fall into the trap of just reading PROPERTIES
command feedback that it is zero, type zero manually to bring it down).
Dean Saadallah
http://LTisACAD.blogspot.com
0 Kudos
Post 3 of 6
10-14-2008 05:21 PM in reply to: geoffamos
Been there done that. Doesn't change anything. Any other suggestions? Geoff
0 Kudos
Post 4 of 6
10-15-2008 01:40 AM in reply to: geoffamos
Ok, more information. I have now copied everything (including the suspect text) into a new drawing (using copy and paste), and the problem disappears - text looks good in Model tab. Any ideas why? Geoff
*Dean Saadallah
Post 5 of 6
10-15-2008 05:43 AM in reply to: geoffamos
You changed the UCS settings, same problem.
Dean Saadallah
0 Kudos
Post 6 of 6
10-15-2008 04:55 PM in reply to: geoffamos
Ummm... no I didn't. UCS is still set at World.
Post to the Community
New Post
