AutoCAD 2007/2008/2009
Member
da.chisel
Message 1 of 9 (5,314 Views)
Text auto-rotate problem
5314 Views, 8 Replies
05-19-2011 06:51 AM
I am having a problem with inserting/editing text in simple 2D cad drawings :
When I click on MTEXT, my cursor changes to the usual text box insertion icon, but the text appears vertical (as if rotated 90º). And entering text (no matter how big or small the MTEXT box is) the text also appears vertical.
When I try to edit text from older drawings (done prior to having this problem), the same problem occurs : The text changes orientation and goes vertical.
I have to manually rotate the text back to the horizontal position every time, and it is annoying.
This is a problem that started occuring in the past week (no changes that I know of were made to autocad settings).
Help please!
Patchy
Message 2 of 9 (5,307 Views)
Re: Text auto-rotate problem
05-19-2011 07:19 AM in reply to: da.chisel
Attach your drawing here, let's take a look.
Member
da.chisel
Message 3 of 9 (5,304 Views)
05-19-2011 07:23 AM in reply to: Patchy
Here it is..
Patchy
Message 4 of 9 (5,302 Views)
05-19-2011 07:33 AM in reply to: da.chisel
Never use the @Arial...  Use the Arial instead.
Member
da.chisel
Message 5 of 9 (5,287 Views)
05-19-2011 07:51 AM in reply to: Patchy
Thank you :smileyhappy: This solved my issue.
New Member
daffouk
Message 6 of 9 (4,823 Views)
02-20-2012 06:49 AM in reply to: da.chisel
Thanks for this answer, it solved my rotating text problem too
Dave
heinsite
Message 7 of 9 (4,794 Views)
02-25-2012 03:28 PM in reply to: Patchy
>... Never use the @Arial... ...<
... Unless you specifically *want* your text rotated 270 degrees that is.  And sometimes you just might.
All of the "@" fonts will do this btw.  Not just @Arial.
Dave
Dave Hein, P.E.
JGerth
Message 8 of 9 (4,747 Views)
03-02-2012 12:24 PM in reply to: heinsite
begs the question....what are the @something fonts?  I _only_ see them in Acad, never observed them in any other application.  and they seem to proliferate...
Edited by
Discussion_Admin
New Member
TIMVETTER
Message 9 of 9 (1,975 Views)
10-28-2013 05:09 AM in reply to: Patchy
Thank you! I can now sleep better at night.
