AutoCAD 2007/2008/2009
Distinguished Contributor
isaacrs
Message 1 of 25 (123 Views)
stretch command
123 Views, 24 Replies
04-24-2008 05:58 AM
I'm looking for a stretch command that I can place on my tool pallete. I navically want it to allow me to select the command then do a crossing window that will select everything to stretch a certain distance. Like stretch everything right 2 inches. Any ideas?
kevinpchandler
Message 2 of 25 (123 Views)
Re: stretch command
04-24-2008 06:09 AM in reply to: isaacrs
Create a custom button macro. Try some code like this:
STRETCH C \\2,0;;
isaacrs
Message 3 of 25 (123 Views)
Re: stretch command
04-24-2008 06:24 AM in reply to: isaacrs
That's kinds what I'm trying to do. It needs to go like "stretch" then you select the items "enter" then "d" for displacement then "0'-2", 0-0, 0-0". Then "enter". I figured there was someone out there savvy enough to help me with this.
jackshield
Message 4 of 25 (123 Views)
Re: stretch command
04-24-2008 07:16 AM in reply to: isaacrs
maybe i misunderstand, is this not how the stretch command already works?
i iniate strecth command, select items to stretch, and either do @ 3 point entry, or with ortho on, move my cursor in desired direction and type number
kingtut
Message 5 of 25 (123 Views)
Re: stretch command
04-24-2008 07:21 AM in reply to: isaacrs
The wheel is already round.
What if your window includes a tiny part of a circle? You stuck.
jackshield
Message 6 of 25 (123 Views)
Re: stretch command
04-24-2008 07:28 AM in reply to: isaacrs
huh?
kingtut
Message 7 of 25 (123 Views)
Re: stretch command
04-24-2008 08:01 AM in reply to: isaacrs
he wants auto stretched, just window and it stretch 2"
How do you stretch a circle?
isaacrs
Message 8 of 25 (123 Views)
Re: stretch command
04-24-2008 08:07 AM in reply to: isaacrs
That's correct. A 2" auto stretch or whatever length.
n7pam
Message 9 of 25 (123 Views)
Re: stretch command
04-24-2008 09:41 AM in reply to: isaacrs
The only way I know how to do this is to follow these steps:
1) Select objects
2) Make a block of the selection set
3) Insert the block with whatever scale you want in whatever direction(s).
4) Explode the insertion
5) Purge the temporary block definition
Since this involves several steps, this process can/should be programmed. The one I ended up writing allows the user to specify which axis or combination of axisesi (sp?) to be stretched (uh, scaled). I am sure there are limitations to the object types that can be used with this method (i.e. solid models) but it works for my purposes. Give it a shot manually and I think you'll be pleased with the results.
jackshield
Message 10 of 25 (123 Views)
Re: stretch command
04-24-2008 11:29 AM in reply to: isaacrs
but he would need to enter value?
or preset to a value?
you dont stretch a circle
