Hello all.
Im trying to create an stl file. I use the command STLOUT and use follow the on screen prompts. However, It produces a ctl file instead!!
I'm running AutoCAD 2009 if that makes any difference.
Any help would be greatfully received
Johnny
Do you have a solid body in your file (you can run List to check for 3D Solid)?
Can you attach the *.dwg file here?
