AutoCAD 2007/2008/2009
New Member
0 Kudos
Post 1 of 4
Specify Displacement
201 Views, 3 Replies
07-20-2012 07:07 AM
Good morning, if there is anyone who can help, I use AutoCAD 2007. When I go to move something, either in model, or, paper space the object is automaticlly set to 0,0,0. And when I hit enter that where the object goes. I have tried to use "Control D" command to turn "Dynamic UCS"  off or on, that doesn't work either. If anyone can help, thanks and have a great day.
67 Kudos
Post 2 of 4
Re: Specify Displacement
07-20-2012 03:04 PM in reply to: Bayouboy637
For the MOVE command and others, after selecting the objects, you have to specify a
beginning point by selecting a point on the screen with your mouse. If you do not, it will be 0,0.
The only other thing I can think of is when you hit [Enter] after selecting the objects,
your keyboard is sending out [Enter][Enter], which seems to me this is what you are describing.
Scot-65
Dyslexia is a permanent physical disability that cannot be seen.
Introverts is proof that there is indeed intelligent life on this planet.
New Member
0 Kudos
Post 3 of 4
09-11-2012 09:07 AM in reply to: Bayouboy637
Did you figure this out?  I have the same problem and it drives me crazy!
2,120 Kudos
Post 4 of 4
09-12-2012 10:43 AM in reply to: pbutler
Keep in mind that somewhere along the line relative became default rather than absolute.
relative @
absolute #
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
