AutoCAD 2007/2008/2009
Valued Contributor
jsnortin
Message 1 of 4 (261 Views)
Right Click shortcut lost
261 Views, 3 Replies
10-03-2012 12:49 PM
I recently noticed that when I right click I don't get the shortcut menu to come up. Everything is set right in my options. I did find if I switch profiles it works. But I want to use the profile I have been using forever. Is there something corrupted in the profile I can fix? Oh yeah pickfirst and noun/verb are set right also.
scot-65
Message 2 of 4 (250 Views)
Re: Right Click shortcut lost
10-03-2012 03:15 PM in reply to: jsnortin
You may have turned on the right-click mode that us "old-timers" are used to using.
Discipline yourself to hold the right-click a little longer or look inside OPTIONS...
Scot-65
Dyslexia is a permanent physical disability that cannot be seen.
Introverts is proof that there is indeed intelligent life on this planet.
Valued Contributor
jsnortin
Message 3 of 4 (233 Views)
10-05-2012 12:56 PM in reply to: scot-65
Thank You. But I already have everything set right. It's something corrupt in my profile I think.
Alfred.NESWADBA
Message 4 of 4 (225 Views)
10-05-2012 10:03 PM in reply to: jsnortin
What happens then when you do a right-click?
If there is real nothing (look to the command-line also!) then you may check your settings for the mouse-buttons in the Windows control panel or change the mouse.
- alfred -
Alfred NESWADBA
