AutoCAD 2007/2008/2009
Valued Contributor
0 Kudos
Post 1 of 3
Reverse Revision Cloud
2684 Views, 2 Replies
07-12-2008 06:26 AM
Does sombedy have a lisp code that automatically reverse or inverse after creating a revision cloud. I mean without using the mouse right click.
Distinguished Contributor
6 Kudos
Post 2 of 3
Re: Reverse Revision Cloud
07-15-2008 08:23 AM in reply to: ajustin
isnt that an option of the command?
*Bill DeShawn
Post 3 of 3
07-16-2008 08:24 PM in reply to: ajustin
Yes. It is. However, it's only present if you select an object by which to
make the cloud. So, this is what you do. Run the command again, select the
Object option, select the existing backwards cloud and when asked to reverse
the direction, type Y for yes.
_________________________
Bill DeShawn
bdeshawn@nospamsterling.net
http://my.sterling.net/~bdeshawn
Notice: New LISP tool for Landscape
Design and for ATTEXT users.
Measure and Divide with attributes!!
wrote in message news:5981772@discussion.autodesk.com...
