AutoCAD 2007/2008/2009
New Member
bruce
Message 1 of 11 (745 Views)
REVCLOUD
745 Views, 10 Replies
08-15-2007 07:37 AM
According to the Help Index, typing REVCLOUD at the command prompt should yield [Arc Length/Object/Style] and enable me to convert a polyline to a revcloud.
When I type REVCLOUD, I get [DS> Angle/Length/] which only allows me to create a revcloud by tracing. I have never been able to convert a polyline to a revcloud. How do I change my settings so that I can convert a polyline to a revcloud.
Distinguished Contributor
steve216586
Message 2 of 11 (745 Views)
Re: REVCLOUD
08-15-2007 07:40 AM in reply to: bruce
Try typing "object" or "O" at the prompt. Some are hidden.
*mkh
Message 3 of 11 (745 Views)
Re: REVCLOUD
08-15-2007 08:17 AM in reply to: bruce
I think you are getting the Dotsoft or Toolpac revdate command.
MKH
wrote in message news:5690500@discussion.autodesk.com...
revcloud.
*ddpcad
Message 4 of 11 (745 Views)
Re: REVCLOUD
08-15-2007 05:29 PM in reply to: bruce
> MKH
here I get
Command: revcloud
Initializing... REVCLOUD loaded.
Select a polyline:
which I thought was the vanilla acad routine but looking at HELP the
command line should say:
Specify start point or [Arc length/Object/Style] :
I use ToolPac 11.0 for revclouds
Command: drc
DS> Chord Length: 0.5000 Angle: 120.0
DS> Angle/Length/Object/:
Dave
DDP
robjames
Message 5 of 11 (745 Views)
Re: REVCLOUD
08-16-2007 02:21 AM in reply to: bruce
Be careful putting revclouds on drawings... you never know how they may be interpretted!
Active Contributor
ROBERT-COLIN
Message 6 of 11 (745 Views)
Re: REVCLOUD
08-16-2007 03:06 AM in reply to: bruce
thanks for that, cheered me up no end
*Dean Saadallah
Message 7 of 11 (745 Views)
Re: REVCLOUD
08-17-2007 05:37 AM in reply to: bruce
type .REVCLOUD (note the period), that should give you the core command to
use, as described in Help.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
*ddpcad
Message 8 of 11 (745 Views)
Re: REVCLOUD
08-17-2007 07:47 AM in reply to: bruce
not here?
Command: .revcloud
Select a polyline:
mgalicki
Message 9 of 11 (401 Views)
Re: REVCLOUD
12-14-2012 06:29 AM in reply to: *ddpcad
When I want to change something with the Options I get an error:
unable to load dialog.
See screen shot attached.
Thanks for your input.
Everything in existence was first an Idea
Autodesk Plant 3D Premium 2012
Autodesk MEP 2015
HP 3.2 Ghz CPU 16 ram
1TB 7200 rpm SATA 3Gb/s hard drive
2GB DDR3 NVIDIA GeForce GT 530
HP 2311x 23" LED Monitor
pendean
Message 10 of 11 (386 Views)
Re: REVCLOUD
12-15-2012 06:49 AM in reply to: bruce
Reinstall AutoCAD may be the fix if you can't get OPTIONS to open.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
