It would be so so great if Autodesk would make the "Replace Block" command actually do aomething. I can replace parts in Solidworks without issue, but in a much simpler 2D environment, replacing blocks is next to impossible unless it's a block of a very very simple shape or something. Could be a great asset if they got it working correctly.
I couldn't say whether they will do what you want, but try the attached things. The BRA [= Block Replace: All] command in BlockReplace.lsp is similar to AutoCAD's BlockReplace command, except that:
1) it doesn't offer a list to pick from, nor on-screen selection [I have in mind to work that in] for the replacing Block, but needs you to type in a Block name [it does let you pick one for the Block to be replaced];
2) it doesn't offer the option of Purging the replaced Block definition;
3) it does, however, find drawings in the Support File Search Path list, and does not require the replacing Block to be already defined in the drawing if it's in one of those locations;
and maybe a few other little things.
The BRS [= Block Replace: Selection] command has you select only those Blocks you want replaced, rather than replacing all Blocks of a given name [and will replace Blocks of any name, not of only a single name, with the designated replacement Block].
Though it's not equivalent to BlockReplace, I include BlockDupNewName.lsp [BDN command] as another kind of "replacement" of a Block [pick one, and give it another name, and it makes a duplicate under the new name, which you can then edit without affecting other insertions of the original Block].
If anyone finds this looking for that kind of functionality, don't use the one in the .zip file attached to Message 3, but get the upgraded version of BlockDupNewName.lsp, >here<.
