AutoCAD 2007/2008/2009
Distinguished Contributor
dmmeehan
Message 1 of 7 (3,663 Views)
Remove wipeout?
3663 Views, 6 Replies
10-07-2008 05:58 AM
I have a piece of mtext with a wipeout that I can't get rid of. I turn on frames but the frame is linked to the mtext. When I try and erase the frame I lose the text. I can't seem to remember how to disassociate the wipeout from the mtext.
*Erik Deyo
Message 2 of 7 (3,663 Views)
Re: Remove wipeout?
10-07-2008 06:55 AM in reply to: dmmeehan
Check & see if background mask is turned on in
the text properties.
Erik Deyo
I
mtext.
dmmeehan
Message 3 of 7 (3,663 Views)
Re: Remove wipeout?
10-07-2008 07:02 AM in reply to: dmmeehan
Unfortunatly it is not a mask. I have currently resized the wipeout so its very small and does not hide background objects but I would like to know what happened. I used to be able to erase wipeouts and not lose the text. I thought there was some kind of variable that sets whether or not the frame is attached to the object?
*Lance White
Message 4 of 7 (3,663 Views)
Re: Remove wipeout?
10-07-2008 07:12 AM in reply to: dmmeehan
Explode it and see what happens.
Lance White
CAD Manager
HP 4600 4 GB Ram
Intel Core 2 Duo 2.66
ATI FireGL V5600
(8.391.2.1100)
Windows XP PRO (SP 3)
2008; (All SP) LDT, MAP 3D
2009;
Civil 3d 2009 Update 1 Version 2, Map 3D, Raster
Unfortunatly
object?
*Michael Hunt
Message 5 of 7 (3,663 Views)
Re: Remove wipeout?
10-07-2008 07:26 AM in reply to: dmmeehan
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Grouping may be turned on.  Try
turning off grouping CTRL-SHIFT-A and see if they can be selected
independently.
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Mike
"Lance White" <WhiteL(at)etmincdotcom> wrote in message
href="news:6046309@discussion.autodesk.com">news:6046309@discussion.autodesk.com
Lance White
CAD Manager
HP 4600 4 GB Ram
ATI FireGL V5600
(8.391.2.1100)
2009;
Unfortunatly
object?
Kali_
Message 6 of 7 (3,663 Views)
Re: Remove wipeout?
10-07-2008 07:34 AM in reply to: dmmeehan
Here are two ways to remove the wipeout from your text.
Command entry: textunmask
Then select the text .
Or by hitting CTRL+ALT+A to toggle PICKSTYLE=0 you can turn off the group association that is connecting the wipeout to the text. With PICKSYTLE=0 you can erase the wipeout frame without erasing the text. If you do it this way may want to set PICKSTYLE=1 when you are done. Again CTRL+ALT+A will toggle PICKSTYLE back and forth between 1 and 0.
dmmeehan
Message 7 of 7 (3,663 Views)
Re: Remove wipeout?
10-07-2008 07:43 AM in reply to: dmmeehan
That was it. Thanks Mike Hunt!
Announcements
Need installation help?
