AutoCAD 2007/2008/2009
JonnyM32
Message 1 of 28 (2,252 Views)
Accepted Solution
Remove unreferenced .jpg from x-ref manager in AutoCAD 2008 LT
2252 Views, 27 Replies
06-29-2011 08:11 AM
Does Anyone know how to remove Unreferenced .jpg From the x-ref Manager. in AutoCAD 2008 LT
Everytime i open drawings it looks for things that arent there and therefore slows the drawing down.
any ideas??
So far the only option I have seen is to Wblock it to a new drawing. If it was 1 print I could do it for you.
*Expert Elite*
Patchy
Message 2 of 28 (2,250 Views)
Re: Remove unreferenced .jpg from x-ref manager in AutoCAD 2008 LT
06-29-2011 08:24 AM in reply to: JonnyM32
Detach it.
JonnyM32
Message 3 of 28 (2,247 Views)
06-29-2011 08:26 AM in reply to: Patchy
if it was as easy is that do you think i would have posted on the forum.
it has unload or reload, and whichever one you select it does nothing as its not referenced to anything.
any more suggestions???
*Expert Elite*
Patchy
Message 4 of 28 (2,241 Views)
06-29-2011 08:32 AM in reply to: JonnyM32
Wow, did I say detach it, or I said unload it ?
JonnyM32
Message 5 of 28 (2,239 Views)
06-29-2011 08:34 AM in reply to: Patchy
well thank you for all your helpful information, i though forums were for help not sarcasm.
*Expert Elite*
Patchy
Message 6 of 28 (2,231 Views)
06-29-2011 08:41 AM in reply to: JonnyM32
 " i though forums were for help "
HOW MUCH MORE HELP DO YOU WANT?
DETACH is different than UNLOAD
JonnyM32
Message 7 of 28 (2,227 Views)
06-29-2011 08:44 AM in reply to: Patchy
yeah, do you read what i put there or not, When i press on unload it doesnt go anywhere it is still there,
IT WILL NOT UNLOAD no matter how different it is, it is unreferenced there is no jpeg there, i want to remove it from the x-ref manager as when i open the drawing it is looking for an image that isnt there.
DO YOU UNDERSTAND, DID YOU LOOK AT THE IMAGE I ATTACHED
Valued Contributor
ossmo02
Message 8 of 28 (2,223 Views)
06-29-2011 08:45 AM in reply to: JonnyM32
It sounds like there may be an error in the OP's install if detach is not available.
You should see this page;
http://forums.autodesk.com/t5/AutoCAD-2007/Detaching-unreferenced-Images/m-p/1603831/highlight/true#...
it may help your situation
JonnyM32
Message 9 of 28 (2,206 Views)
06-29-2011 08:52 AM in reply to: ossmo02
thanks for your reply, i have looked at that article you provided and tried the command, but still nothing, i have attached some images for you to see.
That might be a solution for full blown autocad where as i am looking for LT solution.
*Expert Elite*
Patchy
Message 10 of 28 (2,205 Views)
The image name doesn't have [ ] would this caused a problem?
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
