AutoCAD 2007/2008/2009
JonnyM32
Message 11 of 28 (907 Views)
Re: Remove unreferenced .jpg from x-ref manager in AutoCAD 2008 LT
06-29-2011 08:55 AM in reply to: Patchy
no for example the drawing i am in now:
i have attached another image in where you can see the full name of the jpg
Patchy
Message 12 of 28 (901 Views)
06-29-2011 09:00 AM in reply to: JonnyM32
Never a problem to detach any image for me
Valued Contributor
ossmo02
Message 13 of 28 (889 Views)
06-29-2011 09:06 AM in reply to: Patchy
try the command "CLASSICXREF" if it appears & detach is available then use that
JonnyM32
Message 14 of 28 (889 Views)
do you have full Autocad??
this is what mine comes up as...
also this did show in a previous image i done using classicimage command
JonnyM32
Message 15 of 28 (883 Views)
06-29-2011 09:09 AM in reply to: ossmo02
nope doesnt appear in there either ??
Valued Contributor
ossmo02
Message 16 of 28 (878 Views)
06-29-2011 09:13 AM in reply to: JonnyM32
how large is the file? is it confidential?
JonnyM32
Message 17 of 28 (873 Views)
06-29-2011 09:23 AM in reply to: ossmo02
its not just one drawing, its many, but they are around 250KB
Valued Contributor
ossmo02
Message 18 of 28 (871 Views)
06-29-2011 09:25 AM in reply to: JonnyM32
So far the only option I have seen is to Wblock it to a new drawing. If it was 1 print I could do it for you.
JonnyM32
Message 19 of 28 (867 Views)
06-29-2011 09:33 AM in reply to: ossmo02
yep that worked in getting out the jpeg, thank you for that.
the only problem i am having with the same drawing is that when i open it, it is still looking for something and i am not sure what.  see image i am not sure how to stop this from coming up and just the drawing open???
do you know anything about that??
Valued Contributor
ossmo02
Message 20 of 28 (859 Views)
06-29-2011 11:10 AM in reply to: JonnyM32
I've only ever seen .shx file to be font files in which case you need to get the font from the original source, however it appears to be a shape file not a font.  take a look here
http://forums.augi.com/showthread.php?t=32333
http://forums.augi.com/showthread.php?t=31549
