AutoCAD 2007/2008/2009
JonnyM32
Message 1 of 28 (2,059 Views)
Remove unreferenced .jpg from x-ref manager in AutoCAD 2008 LT
2059 Views, 27 Replies
06-29-2011 08:11 AM
Does Anyone know how to remove Unreferenced .jpg From the x-ref Manager. in AutoCAD 2008 LT
Everytime i open drawings it looks for things that arent there and therefore slows the drawing down.
any ideas??
Patchy
Message 2 of 28 (2,057 Views)
Re: Remove unreferenced .jpg from x-ref manager in AutoCAD 2008 LT
06-29-2011 08:24 AM in reply to: JonnyM32
Detach it.
JonnyM32
Message 3 of 28 (2,054 Views)
06-29-2011 08:26 AM in reply to: Patchy
if it was as easy is that do you think i would have posted on the forum.
it has unload or reload, and whichever one you select it does nothing as its not referenced to anything.
any more suggestions???
Patchy
Message 4 of 28 (2,048 Views)
06-29-2011 08:32 AM in reply to: JonnyM32
Wow, did I say detach it, or I said unload it ?
JonnyM32
Message 5 of 28 (2,046 Views)
06-29-2011 08:34 AM in reply to: Patchy
well thank you for all your helpful information, i though forums were for help not sarcasm.
Patchy
Message 6 of 28 (2,038 Views)
06-29-2011 08:41 AM in reply to: JonnyM32
 " i though forums were for help "
HOW MUCH MORE HELP DO YOU WANT?
DETACH is different than UNLOAD
JonnyM32
Message 7 of 28 (2,034 Views)
06-29-2011 08:44 AM in reply to: Patchy
yeah, do you read what i put there or not, When i press on unload it doesnt go anywhere it is still there,
IT WILL NOT UNLOAD no matter how different it is, it is unreferenced there is no jpeg there, i want to remove it from the x-ref manager as when i open the drawing it is looking for an image that isnt there.
DO YOU UNDERSTAND, DID YOU LOOK AT THE IMAGE I ATTACHED
Valued Contributor
ossmo02
Message 8 of 28 (2,030 Views)
06-29-2011 08:45 AM in reply to: JonnyM32
It sounds like there may be an error in the OP's install if detach is not available.
You should see this page;
http://forums.autodesk.com/t5/AutoCAD-2007/Detaching-unreferenced-Images/m-p/1603831/highlight/true#...
it may help your situation
JonnyM32
Message 9 of 28 (2,013 Views)
06-29-2011 08:52 AM in reply to: ossmo02
thanks for your reply, i have looked at that article you provided and tried the command, but still nothing, i have attached some images for you to see.
That might be a solution for full blown autocad where as i am looking for LT solution.
Patchy
Message 10 of 28 (2,012 Views)
The image name doesn't have [ ] would this caused a problem?
