AutoCAD 2007/2008/2009
Member
nshooty
Message 1 of 8 (5,527 Views)
Raster Image Won't Print To PDF
5527 Views, 7 Replies
01-30-2008 02:35 PM
I have an aerial photo in my drawing and when I print to PDF everything shows up except the image. I am not using the DWGtoPDF.pc3, I have Adobe PDF creator that I use. I can send the exact same file to my plotter and the image prints fine. I thought that maybe it was the PDF creator. So I opened the file up in AutoCAD 2004 and printed the same exact file (down saved of course) to PDF using the same Adobe creator and the image shows up fine. I am guessing that there is probably some setting in 2008 that is preventing the image from plotting? Can anyone help?
*Dean Saadallah
Message 2 of 8 (5,527 Views)
Re: Raster Image Won't Print To PDF
01-31-2008 05:56 AM in reply to: nshooty
Have you tried the built-in pdf driver?
Does it work at all plotting to the dwf driver from 2008?
Dean Saadallah
http://LTisACAD.blogspot.com
Add-on products for LT
http://www.pendean.com/lt
Active Contributor
rwhip12
Message 3 of 8 (5,527 Views)
01-31-2008 06:20 AM in reply to: nshooty
I have the same thing happening with line work on top of an aerial with the exception; it plots a portion of the aerial and all of the line work.
Member
nshooty
Message 4 of 8 (5,527 Views)
01-31-2008 08:05 AM in reply to: nshooty
Yes. I have tried the built in driver. When I have used it the image does show up but I have found that it ignores all my linewieghts. I have used the Adobe PDF distiller for years and have not had a problem until I started using 2008. Again, all of the line work in the drawing prints, just not the photo. I have also noticed that there is an error pop up window that appears right after the printing progress window finishes. It flashes on the screen so fast that I cant read it. Also, when it is finished printing I click the "plot and publish details" window and it says the sheet job was canceled.
Active Contributor
williew
Message 5 of 8 (5,527 Views)
02-20-2008 04:28 AM in reply to: nshooty
Hi nshooty
Have you find a way to plot to PDF the drawings with Images with AutoCAD 2008? We are having simmilar problems with 2008. We have drawings that were created with Autocad 2000 and that plotted fine to PDF with all the previous versions with AutoCAD, but doesn't want to work with 2008? We have also tried to plot the drawings to DWF, also nothing.
Any luck?
Member
nshooty
Message 6 of 8 (5,527 Views)
02-29-2008 02:38 PM in reply to: nshooty
I found a solution that works for me. What I found is that the Adobe PDF driver I was using was set by default to print at 1200dpi. This is way overkill and it was trying to create this huge file, which it obviously can't do. I am not sure why it was set to 1200dpi. I have never had any problems with the previous versions of CAD. How I fixed it is in the plot menu if you select the Adobe PDF as the plotter. Click the properties button, once that window pops up click on custom properties. That should bring up the PDF Document Properties window. Click either the layout tab or the paper/quality tab. Click on the Advanced button. Expand the Graphic section and you can change the 1200 dpi. I use 300 dpi and have never had any resolution problems. After you adjust that you will need to create a new .pc3 file or update your existing one. If you do not save this setting it will automatically go back to 1200dpi after you print.
Good luck!
Member
LAmatt
Message 7 of 8 (5,400 Views)
01-17-2011 11:51 AM in reply to: nshooty
YES!
I was having a similar problem in ACAD 2009 today, and previously never had the issue in older versions (was working in 2007 until recent weeks). Changing the default PDF dpi from 1200 to 300 solved the problem for me as well. I had to restart AutoCAD after making the change to the pc3 file - I don't know why, but once I did, hours long headache appears to be solved. Thanks for the tip.
Member
polsixe
Message 8 of 8 (133 Views)
10-06-2014 08:46 AM in reply to: LAmatt
Changing the print quality to 300 dpi from 1200 dpi is confirmed still is the way to fix this problem for AutoCad 2015.
Post to the Community
New Post
Need installation help?
