Hi, recently I upgraded from a 32 bit operating system to a 64. Everything has been working fine and dandy up until publishing. From the publish manager either it wont plot any of the sheets or just the first page out of muiltiple.
I've attached a picture.
Let me know if you require any further details. Thanks!
verify the setting of the sysvar PUBLISHCOLLATE (>>>details<<<)
- alfred -
Thanks for the quick reply.
PUBLISHCOLLATE when switched to "0" did allow each sheet to be printed as a seperate PDF file
although
PUBLISHCOLLATE when switched to "1" only printed the first sheet (once again).
I'm looking for the full sheet set to be in one PDF file or from the printer.
I have tried this feature ( http://forums.autodesk.com/t5/autocad-2013-2014-2015/publish-multiple-pages/td-p/4300637 ) suggested by jingy but still no luck.
Have you tried this option setting during the publish?
