AutoCAD 2007/2008/2009
New Member
0 Kudos
Post 1 of 8
Problems with copy and paste from different files
506 Views, 7 Replies
09-21-2012 01:50 AM
Hi everyone,
I've got some problems using copy and paste command for copy objects from different files.
Sometimes the operation take me just few seconds, sometimes (say the 70% of the times) take me more than 20mins....and it's so frustrating and boring!
I've read that could be a ram problem, but the pc is new!
I've also try to use Scalelist command, but it doesn't work......Autocad says to me that there is a "error in the system"
what can I do?I'm using an Autocad2008 version on Windows7, could be possible have a "conflictual problems" between the 2 systems?
Thank you for your helping
1,589 Kudos
Post 2 of 8
Re: Problems with copy and paste from different files
09-21-2012 05:22 AM in reply to: zizi.goletta
win7 is not supported for R2008, so yes that is a big deal, it means no one is trying to fix any issues.
But, that should not happen unless the content of your drawings are the trigger: by chance can you post a DWG with this exact problem for someone here to try?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
New Member
0 Kudos
Post 3 of 8
09-21-2012 06:03 AM in reply to: pendean
That's the point, win7 is not create for support cad2008..It's like I was suppose!
No don't worry, now that I discover the problem I'll use another pc :smileyhappy:
But anyway thank u so much!
Best regards
Active Contributor
0 Kudos
Post 4 of 8
10-01-2012 09:21 AM in reply to: zizi.goletta
0 Kudos
Post 5 of 8
10-12-2012 07:03 AM in reply to: zizi.goletta
Im working on 2008 CAD and simple copy and paste in the draing takes forever. I tried the lisp command but nothing changed. still have to wait for simple copy and past... whats up with this?
0 Kudos
Post 6 of 8
10-12-2012 07:04 AM in reply to: anoopvarrghese009
Im on Win XP 64bit
Active Contributor
0 Kudos
Post 7 of 8
10-12-2012 08:42 PM in reply to: zizi.goletta
Command: -SCALELISTEDIT
Reset, Enter
Yes, Enter
 Exit
Do this steep in Both Drawing.
Then Try.
    This command available Auto Cad 2008 and above only
http://lispandtips.blogspot.com/2012/10/copy-and-paste-from-different-files.html
190 Kudos
Post 8 of 8
10-15-2012 07:28 PM in reply to: anoopvarrghese009
I've recently upgraded the computer I use and it came with Win 7 Professional 64 bit. To install ACAD 2008, I used the XP Mode which sets up a virtual machince running XP. I then installed ACAD into this virtual machine so I have the better OS running for everything else and ACAD running in the old 32 bit OS with no conflict issues. Althoug I do have to find the latest accepted video card list from Autodesk and install it for the performence settings to work properly.
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
