AutoCAD 2007/2008/2009
New Member
0 Kudos
Post 1 of 9
polyline looks "hollow" instead of solid
9369 Views, 8 Replies
02-26-2010 01:49 AM
Tyring to pur a dashed line on a drawing. On some drawings it works fine, and looks like a dashed line of width 10 with a solid colour filling the full width of the line.
However, on some drawings the very same procedure leaves me with a polyline that is not filled wioth colour, and I just have the outline of the line shown. When this happens, the line looks fine on layout space, but I would like it to look right in model space too.
Any reason why the line behaves differently on different drawings, and any suggestions as to how I can get it to be a solid colour instead of just an outline?
Wayne
*Dean Saadallah
Post 2 of 9
Re: polyline looks "hollow" instead of solid
02-26-2010 05:22 AM in reply to: waynesurvey
FILL variable
SHADEMODE to set to 2D
viewport has Hide turned on.
Rotated UCS.
Dean Saadallah
http://LTisACAD.blogspot.com
New Member
0 Kudos
Post 3 of 9
11-30-2011 03:34 PM in reply to: waynesurvey
I have the same problem.
FILL is set to "1".
SHADEMODE is set to "2D wireframe" (I am not using 3D for this drawing)
Viewport is not hidden.
However, I have changed the UCS.  How does one correct this problem with a rotated UCS?
thanks!
Cara
*Expert Elite*
312 Kudos
Post 4 of 9
12-07-2011 07:41 AM in reply to: cday7845
do not use wide plines to represent line thickness, use lineweight property instead.  Or create the plines in plan view only.
*Expert Elite*
28 Kudos
Post 5 of 9
07-04-2012 08:52 AM in reply to: JGerth
I tried everything from multiple posts. SHADEMODE set to 2D was the 1 setting that changed it. Mind you FILLMODE is set to 1, and UCS - World, PLAN - World... were the other settings. Why do some people just change random things at random times, just leave normal alone or go paint on a canvas. :smileywink:
New Member
1 Kudo
Post 6 of 9
11-27-2012 11:31 AM in reply to: waynesurvey
Spoiler
I recently had the same issue but discovered it when I exploded a leader line. The arrow head lost it's fill but was still a solid. All the appropriate settings were correct. What solved the "Hollow" polyline and the arrow head issue was...from the VIEW pulldown----3d views----Top view. For whatever reason someone had changed the view of the drawing I was working on. Hope this helps.
Ray
Active Member
1 Kudo
Post 7 of 9
12-05-2012 02:15 PM in reply to: ray.kuras
I have had this happen a couple times to me and what I have found is that you are out of plane with the plan view. If you type plan to reset the view that has fixed it for me.
New Member
1 Kudo
Post 8 of 9
09-19-2013 01:36 PM in reply to: JGerth
I believe the OP was looking for the answer to a specific question, not your opinion of proper drawing teqnique.
*Expert Elite*
370 Kudos
Post 9 of 9
09-20-2013 05:15 AM in reply to: bmkikstra
Welcome to the Autodesk Forums!
Yea; probably hard to tell exactly what the OP wanted three years ago.
I'm pretty sure there are those who would tell you to do it with Plotstyles as well.
And then you get into the whol CTB / STB controversy. This could be ong thread when all is said and done. :smileywink:
Thanks for chiming in!
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
