I am having an issue with the precision displayed for my AECC points. They randomly decide to round up or down to whole numbers. When I list a point it still has the point listed to the hundreth position but in the drawing it is rounded. I will be working on something completely different in the drawing and the precision will randomly change.For instance, they were just displaying to the hundreth in my drawing while I was working on a sewer line. I turned all layers back on and did a regen. When it regenerated the points were rounded again. I am using Land Desktop '07. I'm at a loss and any help would be appreciated.
Unfortanately, I have tried the drawing setup menu and it is still set to the hundreth position. I have manually created all the points with the create points menu. I have found a temporary cure for when I go to print, but this proves problematic when I have to send the drawing to someone else. I have found that if I go into the display properties under the edit points menu, text tab, and check the number option (I only display the elevation and description) and hit ok, they all pop back to the hundreth. I can then go in and uncheck the box and hit ok and they remain and I can print. However, if I zoom, regen or any number of things then they revert back to only displaying whole numbers. Strangely the same does not occur if I do these exact steps in the points setting.
