AutoCAD 2007/2008/2009
Active Member
pbyrnej
Message 1 of 5 (519 Views)
Patent Drawing on AutoCAD 2008?
519 Views, 4 Replies
10-11-2007 10:48 PM
I'm seriously considering purchasing AutoCAD 2008 to use as my primary drafting software. I've searched for what was previously said about patent illustration, but the threads were quite dated (5-7 years ago), and I'm not sure if what was said then is still true today. What I want to ask is:
1. Considering that up till now most of my work has been tracing, should I get (A) AutoCAD 2008, or (B) AutoCAD 2008 LT? I think I'll still need to use the modeling aspect of AutoCAD for my work, so I'm undecided between the two.
2. Should I use AutoCAD, or could I use another Autodesk brand product for my patent illustration needs?
*Laurie Comerford
Message 2 of 5 (519 Views)
Re: Patent Drawing on AutoCAD 2008?
10-12-2007 01:06 AM in reply to: pbyrnej
The best way is to get LT and see if it does what you need. If it proves
inadequate, upgrade it to the full AutoCAD. Any learning of LT will be
directly useable in the full version.
Check with your local dealers what the economics are.
Laurie Comerford
CADApps
www.cadapps.com.au
www.civil3Dtools.com
wrote in message news:5747741@discussion.autodesk.com...
two.
*Dean Saadallah
Message 3 of 5 (519 Views)
10-13-2007 01:48 PM in reply to: pbyrnej
Have you looked at cheaper, easier to use CAD programs? AutoCAD has a
steep learning curve... . Start downloading and trying demos of them
all, you need to find what you are comfortable using and willing to
spend time using.
Dean Saadallah
http://LTisACAD.blogspot.com
Add-on products for LT
http://www.pendean.com/lt
JDMather
Message 4 of 5 (519 Views)
10-13-2007 05:12 PM in reply to: pbyrnej
You might have your local reseller demonstrate some of the other Autodesk products. I'm not sure AutoCAD will work very well for typical patent type drawings.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
JDMather
Message 5 of 5 (519 Views)
10-13-2007 05:16 PM in reply to: pbyrnej
The original Inventor Model from which Inventor Studio created the illustration.
