AutoCAD Forum
paperspace/dwf's
10 REPLIES 10
Message 1 of 11
joeac
578 Views, 10 Replies
paperspace/dwf's
I have a 17x11 sheet with a thick border line and tile block in paperspace that I use to
make dwf's using the publish command in AutoCad 2006. I'd like to make a copy of this
and make a 24x18 sheet or page w/ a similar border line and title block. Years ago I
learned how to do this, but age has  up with me, and I just can't remember how
it's done. Is there someone out there who can help me with this?
Thanks, Joe
10 REPLIES 10
Message 2 of 11
pendean
in reply to: joeac
To do it properly you need a 24x18 titleblock first, then you can use PAGESETUP to resize the curent paperspace if creating a new one is not an option.
Message 3 of 11
joeac
in reply to: pendean
Pendean, I've taken the enclosed attachment (24x18)to PAGESETUP and am lost
as to
How you resize it for "current paperspace" .If it's not too much trouble,
could you
Explain to me just how this is done.
Thanks again, Joe
Message 4 of 11
pendean
in reply to: joeac
PAGESETUP command while in your paperspace layout, select a larger page size if 24x18 is available with your plotter driver.
Message 5 of 11
joeac
in reply to: joeac
Pendean,
Using the Pagesetup command while in Paperspace was the answer
to the problem I was having. Thanks for your help with this.
Joe
Message 6 of 11
joeac
in reply to: joeac
Pendean,
How do I create a new sheet (30x24) in paperspace?
Joe
Message 7 of 11
pendean
in reply to: joeac
PAGESETUP command while in your paperspace layout, select a larger page size if 30x24 is available with your plotter driver.
If it's not available, you will need to create a custom sheet size: uit depends on your driver whether you can do that inside AutoCAD or not.
What are you plotting to?
Message 8 of 11
joeac
in reply to: joeac
AutoDesk Review
Message 9 of 11
pendean
in reply to: joeac
That's not a printer or plotter: what are you plotting to?
Message 10 of 11
joeac
Pen, I realize this is not a printer or a plotter. I'm using AutoDesk Review to
send out these dwf's to clients so they can print or plot as they choose. I'd
like a certain sheet size to fit the drawing at a specific scale and right now
I need a 30x24 for some drawings @ 1/4" scale. Can you help me with this?
Joe
Message 11 of 11
pendean
in reply to: joeac
DWF plotter driver finally 😉
May I ask why you don't want to send a "standard" sheet? Either way this following top for AutoCAD should apply to the free viewer (and as far as I know you can do it in AutoCAD 2006 too) http://www.cadforum.cz/cadforum_en/how-to-add-custom-paper-format-to-autocad-grayed-tip9348
”Boost
