I have a 17x11 sheet with a thick border line and tile block in paperspace that I use to
make dwf's using the publish command in AutoCad 2006. I'd like to make a copy of this
and make a 24x18 sheet or page w/ a similar border line and title block. Years ago I
learned how to do this, but age has up with me, and I just can't remember how
it's done. Is there someone out there who can help me with this?
Thanks, Joe
Solved by joeac. Go to Solution.
Pendean,
Using the Pagesetup command while in Paperspace was the answer
to the problem I was having. Thanks for your help with this.
Joe
Pen, I realize this is not a printer or a plotter. I'm using AutoDesk Review to
send out these dwf's to clients so they can print or plot as they choose. I'd
like a certain sheet size to fit the drawing at a specific scale and right now
I need a 30x24 for some drawings @ 1/4" scale. Can you help me with this?
Joe
