AutoCAD 2007/2008/2009
Distinguished Mentor
109 Kudos
Post 31 of 118
Re: One or more objects in this drawing cannot be saved to the specified fo
01-29-2009 10:57 AM in reply to: nrz13
Darin:
We have not encountered this problem since the original post, so I can't test your solution.
I suspect that one of the service packs already fixed this issue, but that's just a guess. There may be people that are still having problems, even with service packs 1 and 2 installed.
______________________________________________________________________________________________________________________________________________________
System specs: AutoCAD 2015 64-bit SP2, Windows 7 64-bit SP1, Intel Core i7-2600K, 16GB RAM, Crucial M4 SSD, AMD FirePro V4900, 2 Dell Monitors (2560x1600)
18 Kudos
Post 32 of 118
01-29-2009 04:36 PM in reply to: nrz13
Purging registered apps does not help. We purge registered apps every time a drawing is opened.
This issue seems to have fixed its self. We have not seen this issue again since September.
Jeff Paulsen
Civil 3D 2012 SP3 | Win 7 64-bit SP1
Xeon E5-1620 @ 3.60GHz, 16GB Ram | NVidia Quadro 600
0 Kudos
Post 33 of 118
Re: One or more objects in this drawing cannot be saved to the specified format
01-30-2009 11:46 AM in reply to: nrz13
Crap, now this is happening on one of my drawings!!! I've tried all of the suggestions below, and I cannot save this drawing!!
HELP AUTODESK!!
Valued Mentor
11 Kudos
Post 34 of 118
01-30-2009 07:53 PM in reply to: nrz13
how about this :
in model space,
1 - select all
2 - erase / Previous / Remove -> window select what you need / enter
3 - audit, purge and wblock or drag to empty dwg ( sometimes works better than wblock)
in paper space : repeat if you need to and copybase/paste to new dwgs paper space.
*Expert Elite*
485 Kudos
Post 35 of 118
03-20-2009 08:41 AM in reply to: nrz13
None of this will work for me. (Haven't tried Super Purge yet) Autodesk told me that this was cause by a defect in the Audit Command and would be fixed in the next release (2010). I also experience the start of this problem when I first select an object and then Raster Design starts.
Allen Jessup, Rockland County Highway Department
Windows XP Pro, SP3
Dell Precision T7400, Xenon X5460, 3.2 GHz, 4 (3.25) GB Ram
NVIDIA Quadro FX 4600, 768MB, driver Ver 6.14.0011.8208
Powerdraft OpenGL drivers Ver 17.2.2
C3D-SP2.1 (Version 3.1), LDTC & RD 2009
0 Kudos
Post 36 of 118
04-10-2009 11:30 AM in reply to: nrz13
Has anyone found a fix for this yet? My computer just started doing this, and it's getting rather annoying to have to do an "audit" every time, before I save a drawing.
Also, not sure if it's related or not but I can no longer copy Layouts within a drawing.
I right click on the Layout tab, select Move or Copy, then check the "create a copy" box and click "ok".
I get a window that reads "ERROR: Copy of Layout "(copied tabs name)" failed."
I'll post the above in another thread, just in case.
Any info would be MOST helpful.
Thanks Edited by: cdaddy on Apr 10, 2009 6:30 PM
*Expert Elite*
485 Kudos
Post 37 of 118
04-13-2009 05:02 AM in reply to: nrz13
As I said Autodesk claims it is a fault in the Audit command and will be fixed in 2010. I have my doubts because of the involvement on Raster Design.
The only workaround I've developed is to create an macro that does an Audit and then a QSave. I've got my on a Tool Palette. Of course it still takes longer to save and you can't rely on Autosave because it will fail every time.
Allen
0 Kudos
Post 38 of 118
04-20-2009 12:07 PM in reply to: nrz13
Since my last post, I have had multiple commands fail due to this "AUDIT" problem. The commands that I have found will ONLY run if I run the AUDIT command first are...
PLOT and Publish
COPY or MOVE Layout Tabs
Saveas and Qsave
you'd think that Audodesk would come up with a fix or update for this. Those of us that are stuck using whatever AutoCAD version the company gives us have our hands tied and would rather have a fix than be be told to wait until the next version comes out. I can't wait that long and would much rather continue using 2009 than have to revert back to 08 or 07, so I can actually get some work done.
*Expert Elite*
485 Kudos
Post 39 of 118
04-20-2009 12:38 PM in reply to: nrz13
2010 has been released. So I don't expect to see any Updates for 2009. I've had to wait for C3D to be released. It's downloadable now but I haven't received the disks. I may start testing it soon but I can't use it for any work I might share with the rest of the office until I'm ready to deploy it.
I'd suggest seeing if your office could switch to 2010. Your problems would justify making it a priority.
Allen
0 Kudos
Post 40 of 118
05-04-2009 12:00 PM in reply to: nrz13
Never had this problem in 2009 but when working on 2009 drawings in 2010 I am now having this problem. Only drawings that have aec content wont save in any format. Dunno what to do none of the above works.
Rob.
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
