AutoCAD 2007/2008/2009
Member
MikeB_SKG
Message 111 of 118 (5,930 Views)
Re: One or more objects in this drawing cannot be saved to the specified format
05-10-2012 10:05 AM in reply to: nrz13
Thank you for your response. Please note that the problem has been solved and was related to the SBS 2011 software (Indexing). The Indexing has been turned off and all issues resolved. Greatly appreciated. Thank You, [3New Logo] Michael Brungard SKG Enterprises, Inc. 9260 East Raintree Drive Suite 140 Scottsdale, Arizona 85260 Ph) 480.998.5600 Email) mikeb@skgaz.com www.skgaz.comThis SKG Enterprises, Inc. e-mail message and any attachment(s), are intended only for use by the addressee(s) named herein and may contain legally privileged and/or confidential information. If you are not the intended recipient(s), or the employee or agent responsible for delivery of this message to the intended recipient(s), you are hereby notified that any use, dissemination, distribution or copying of this e-mail message, and/or any attachment hereto, is strictly prohibited. If you have received, this e-mail in error, please immediately notify the sender and permanently delete the original and any copy of this message. Thank you. P Please consider the environment before printing this e-mail
New Member
alfredgmar
Message 112 of 118 (5,736 Views)
08-24-2012 08:22 AM in reply to: AllenJessup
la respuesta correcta a esta pregunta es AECTOACAD Y SE GUARDA UNA COPIA DEL TIPO WBLOCK
la cual se puede modificar se exporta y queda lista para seguir trabajando y modificando
saludos:smileywink:
Active Member
sharpl
Message 113 of 118 (5,620 Views)
12-17-2012 11:03 AM in reply to: Darin.Green
Didn't do any good, seriously? Such a waste of time ...
Active Member
sharpl
Message 114 of 118 (5,620 Views)
12-17-2012 11:06 AM in reply to: JeffPaulsen
No it doesn't even after 3 times running Audit. Is it Windows 7 bug?
New Member
mustafa_kot
Message 115 of 118 (5,476 Views)
04-04-2013 01:06 AM in reply to: nrz13
Open the '' Purge '' setup from Drawing Utilities in Menu bar, then click to '' Purge nested items '' for make it.
And finally, you'll continue in your drawing smoothly...
Member
MikeB_SKG
Message 116 of 118 (5,472 Views)
04-04-2013 07:30 AM in reply to: mustafa_kot
Thank you for your response. Purge was the very first thing done. We have
also gone through and wblocked out the drawing and started a new drawing,
dxf out and restart an new drawing. None have worked.
We recently have purchased acad 2013. While there is a learning curve to
this new software, at least from 2009 we hope this resolves the problems.
Thank You,
*SKG Enterprises, Inc*.
Michael Brungard
*This SKG Enterprises, Inc. e-mail message and any attachment(s), are
delete the original and any copy of this message. Thank you.*
*P** **Please consider the environment before printing this e-mail*
New Member
mwambsjoe
Message 117 of 118 (403 Views)
03-28-2014 05:10 AM in reply to: AllenJessup
Good afternoon, am seeking help for the above mentioned subject
kmiller
Message 118 of 118 (396 Views)
03-28-2014 06:02 AM in reply to: MikeB_SKG
Have you tried the previous posted suggestions about using wblock and purging the file?  Is it all files, just one file, etc....  What release are you using?  Can you give more information or possibly send a sample file that the issue is happening on?  At this point we use 2013 version software, we have 2014 if needed but have not seen the issue in years.
If this response answers your question please click "Accept as Solution".
Post to the Community
New Post
Need installation help?
