I have a thing with offset command. It offset correctly but also moves my line little bit on a side.
Bigger offset distance - bigger move gap.
How do I fix this?
Solved by Soyoung.H. Go to Solution.
I checked your drawing, but couldn't find any line moving by OFFSET command.
Are you aware of the main line is slightly curved?
no, problem 🙂
Can you accept my above answer as a solution?
So the other people may notice this issue is resolved 🙂
You can do that by clicking the button "Accept as Solution"
