AutoCAD Forum
Not Printing
3 REPLIES 3
apanbasu
537 Views, 3 Replies
Not Printing
I have a drawing with OLE object. When I try to make a PDF - it shows the OLE object along with the Title Block. However it does not print the Ole object or the Title Block. Only a small portion of the Title Block is printed. I tried to create PDF of the OLE Object, again it shows in the preview but, came out white sheet. I have attached the drawing and the PDF.
I checked for non printing of Layers and none is checked for non printing. It happened to me before with a PDF OLE. I scanned the PDF to TIF and exrefed as Raster Image.
I need help.
Thanks.
3 REPLIES 3
pendean
in reply to: apanbasu
If preview shows it, then the problem may well be the driver you are plotting to: you did not share that information. Provide this info please, plus your exact AutoCAD version.
apanbasu
in reply to: pendean
My problem resolved. I ran Computer Clean-up every week and it also cleans the registry. After the post I thought it might have messed up my registry. So, I repaired AutoCAD 2008 and now it is working.
I should have thought of this before my post. In the future what should I look for Registries related to AutoCAD. So that I do not remove those registries.
pendean
We appreciate you posting back with your fix.
”Boost
