AutoCAD 2007/2008/2009
khacho
Message 1 of 6 (377 Views)
new hatch palettes
377 Views, 5 Replies
05-16-2011 11:30 PM
dear all,
how to make new hatch palettes? pl. suggest me.
thanks.
khacho
Valued Contributor
FredBirch2025
Message 2 of 6 (292 Views)
Re: new hatch palettes
05-18-2011 06:13 AM in reply to: khacho
I used a full hatch pallet in my 2008 ARCH ACAD.  I have spent two days trying to import the .xtp file and/or loading a new hatch pallet from scratch into ACA 2011, with no luck so far.  I too would like this tool  repaired, or explained.
pendean
Message 3 of 6 (271 Views)
05-18-2011 09:31 AM in reply to: FredBirch2025
There are two kinds of palettes in ACA and they are not interchangeable: not a problem found in plain AutoCAD where you are posting. And I think the OP wants to create new ones in R2008 but forgot to elaborate on the exact issue.
It seems your ACA forum posting got a lot of eyes (and a few comments from me) but not much else. Consider refreshing it by adding to it to bump it back up the list.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Valued Contributor
FredBirch2025
Message 4 of 6 (267 Views)
05-18-2011 09:43 AM in reply to: pendean
I probably should rewrite this on the ACA board.  I am having this problem on ACA 2011.
The Arch 208 is the revision where I created and used the .xpt every day.  It is a great tool but I can't seem to transfer it or even reload the hatches one at a time.
Please help
How would I transfer this post to ACA
pendean
Message 5 of 6 (267 Views)
05-18-2011 03:04 PM in reply to: FredBirch2025
I suspect... You probably ran ACA2008 "as AutoCAD". Regardless of what the box or the pop-up says, it's a feature of all the verticals.
You are not running ACA2011 "as AutoCAD": to do that, see screenshot of OPTIONS command>Profiles Tab in ACA2011.
There is nothing to fix therefore, you need to correctly install all of ACA2011's features and activate the correct profile.
Valued Contributor
FredBirch2025
Message 6 of 6 (259 Views)
05-18-2011 04:04 PM in reply to: pendean
thank you
