AutoCAD 2007/2008/2009
0 Kudos
Post 11 of 14
Re: Need help drawing line with radius
01-02-2013 06:25 PM in reply to: scot-65
Moshe and Scot, thanks so much. Both of those methods worked for me individually!
*Expert Elite*
67 Kudos
Post 12 of 14
01-03-2013 03:13 PM in reply to: JeffWVULT
Drafting this was automatic as I was formally trained as a "board" person
at the time the word "computer" was defined as a machine that took up the
space of an average sized bedroom and stored data on a magnetic tape.
It took a minute to write these steps sequentially so one can understand.
PUT AWAY THAT CALCULATOR!
Scot-65
Dyslexia is a permanent physical disability that cannot be seen.
Introverts is proof that there is indeed intelligent life on this planet.
*Pro
139 Kudos
Post 13 of 14
01-07-2013 08:38 AM in reply to: JeffWVULT
WOW, guys you really do things the hard way!
Easy is like the following:
Start Pline command:
Draw a vertical line from the top at the desired distance.  (It isn't given so I used 3'):
Change to arc.  Use command line entry - @6,-6 "enter":
then Command line entry again - @5,-5 "enter":
Change to line and complete the vertical line to finish point.  (Again I used 3')
See attached pic.
One command and three clicks.  Simple!
*Expert Elite*
67 Kudos
Post 14 of 14
01-07-2013 03:37 PM in reply to: steve216586
Good observation / solution Steve.
I went with the pretense that the two vertical lines were existing and the OP wanted
to connect these two with arcs of specified radius.
Your solution showed the tangent of the two arcs at the quadrants, which was not
the desired look on the OP's smart phone pic (the vertical lines were closer together
than what you show)...
Scot-65
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
