Hi Autodesk team
My AutoCAD2009 has some problem. The problem is AutoCAD2009 will be turn off automatically when we double click on start icon. And it will appear aleart message "Another program is currently using the file" as capture photo attached file.
I don't know if we remove program and then reinstall , it will be OK or not (I afraid that the request code will be changed as previously)
Could you please give me the solution to fix this problem??
Thank you in advance for the answer.
Pendean
Thank you very much for reply.
This is the new problem on existing PC and I can't restore as your solution due to that PC didn't set automatic backup.
Could you please let me know the exact problem and also other solution??
Your help will be much appreciate.
just to make sure: you have tried to restart your workstation?
- alfred -
Hi Alfred
Thanks for reply.
We try to restart many time but the result still be here.
Could you please let me know the exact problem and solution?
As I ask as above "Can I remove and reinstall AutoCAD2009??" I ask you because I afraid that the request code will be changed as previously.
The exact problem is known to you, you see it.
If anyone would know the "exact solution" I'm sure we would have told you that. But at least I have not seen that type of issue yet. So we can do suggestions/ask questions to come more close and hopefully find then the source of the problem.
In the background in your screenshot there is another messagebox with a C++ Runtime Error, have you tried to install the C++ Runtime Libraries newly?
Does the same error occur if you login to your system with another user-account (having admin rights)?
Can you then tell us what you have installed since AutoCAD run well last time?
- alfred -
Hi, Alfred
Thanks for reply.
>>> Now,I was install visual c++ already. The result is when I start autocad, the messagebox is disappear but
It seem like nothing run. I try to see in task manager on processes tab it has "acad.exe" appear and on applications tab
is not anything run.
>>> Sorry, I don't know because I'm not end user.
Could you please see my video file following my link ? and then you will understand what we try to explain to you.
http://www.mediafire.com/download/j81yzm60z7du75s/Untitled_5.flv
Does It have to format harddisk ?
Hi, Pendean
I was create a new Windows Profile : Administrator and test autocad 2009 already.
But the problem still be existed.
I don't know why I have not mentioned it yet: can you run a repair-install with AutoCAD? (as administrator, disabled antivirus-software).
- alfred -
Hello -Alfred-
I try to repair/reinstall AutoCAD2009 in admin account with out anti virus running but the problem still be existed.
Do we need to format this problem PC ??
Did you do a >>>clean uninstall<<< before starting the new installation?
As the first problem was a C++ library it might help to reinstall all beginning with the OS, but I guess nobody can guarantee that this will help, because something killed the C++ libs and maybe other files too, so that might happen again if you run the same installations again.
Good luck, - alfred -
Hi -alfred-
Thanks for prompt response.
We follow the Autodesk instruction as this link :
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
Is it clean enough ?? Please help to advise the other solution or should we format the harddisk ??
your link is the same as mine, so yes, it's "clean enough".
It's not really necessary as long as you start with installation of the OS into a different partition.
Even better: I would spent a new harddisk so in case of troubles you can restart from the old harddisk to look about files/settings/... you need from the old system..
- alfred -
