I came in this morning and opened AutoCad as usaul and created single line text. I changed the current style and height. I input my text but the width was wrong for that style so I highlighted it and right clicked to bring up the modify menu to choose properties but what happened instead was the last command was re-activated. What ever I do before right clicking always re-actived that particular command no matter what I highlight. Is this a variable issue?
Suggestions appreciated
Russell
Solved by pendean. Go to Solution.
Going to where you suggested I found that the "short cut menus in drawing area" was unchecked. By checking it that brought the menu up but the "properties" was gone and two other functions was on the list that were not there before. You might need to know that I had recently created a new CUI file. Would that have any control over this?
Russell
Never mind, while in the "optons" I found another box unchecked that should have been checked, so all is well or so it seems.
Thank you very much Dean for your help.
Russell
would be nice if you told us what you did exactly so we can fix the issue as well.
Why don't you ask a question instead of criticizing a well intentioned post from five years ago?
Type Options -> User Preferences -> Right-click Customization -> Edit Mode -> Select Shortcut Menu.
