AutoCAD 2007/2008/2009
New Member
Astr4l
Message 1 of 3 (546 Views)
Manipulate Autocad 2007 dynamic block from excel
546 Views, 2 Replies
11-30-2012 12:28 PM
Hi everyone!
 I have a simple question: is it possible to manipulate dynamic blocks from excel (2007) (for example: change a shaft's diamater that is based on an excel calculation)?
**Master
dmfrazier
Message 2 of 3 (521 Views)
Re: Manipulate Autocad 2007 dynamic block from excel
12-13-2012 07:16 AM in reply to: Astr4l
I believe it can be done, but it would require some AutoLISP or VB (or other) programming.
The following post hints at a possible way to do it (see daveea's contribution):
http://forums.autodesk.com/t5/AutoCAD-2008/Copy-excel-data-to-a-Property-Lookup-Table/m-p/2111264/hi...
New Member
Astr4l
Message 3 of 3 (516 Views)
12-14-2012 12:19 AM in reply to: Astr4l
Thank you for the answer! I've already tried to search a lot on the google. I'm looking for a concrete VBA  or LISP code
that, for example, changes a diameter of a dynamic-block defined circle. I carry out this project 'cos i want to demonstrate at my workplace, that the automatization of drawings is possible.
Best regards.
Post to the Community
New Post
Need installation help?
