AutoCAD Forum
Making a frustum from a flat pattern
4 REPLIES 4
JamesCorley
2122 Views, 4 Replies
I know how to get a flat projection from any surface, but how can I transform an oject redrawn from an old set of plans and create a cone or frustum from the flat projection?
Specifically, I am designing a 3d model of a Gemini capsule and have a redrawn sheet from the old McDonnel blueprints. I need to draw this as a skin and wrap it around the basic shape I already have to add the skin detail to the completed model. Eventually it will be a real model.
TIA
4 REPLIES 4
nestly2
in reply to: JamesCorley
Welcome to the Autodesk forums
I don't have your version, but if it's available, the CONE command will create the fustrum
Specify Base Radius
Specify Top Radius
Specify Height
"Skinning" it with a design I believe is beyond AutoCAD's capabilities.
JamesCorley
in reply to: nestly2
Maybe I was unclear on my language.
I have a flat item, made a surface, and it has all sorts of details on it.
I want to "rotate," "revolve," "wrap," or "curl" it into a frustum.
I already have the solid I would like to join it to to change the holes into depressions.
If Autocad can give a flat projection, why not the reverse?
nestly2
Thanks for the clarification.  The answer is still the same though, AutoCAD cannot "wrap" flat geometry around curved geometry.  Autodesk has other software that will, but not AutoCAD.
Also, AutoCAD can't go the other way either... it's limited to projecting from a single perspective onto a single plane in the same way a camera only captures what's facing the lens.
JamesCorley
which versions? I have access to several.
”Boost
