AutoCAD Forum
Loosing multi-text paragraph
5 REPLIES 5
653 Views, 5 Replies
Hey guys! I am having some difficulties with multi text. I create multi text and in paragraph menu turn on line spacing - exactly at 210 and everything is how it should be. But when I close my drawing file and re-open it, the formation of line spacing is lost. I have tried to copy text to different file, but had the same issue. I'm using Autocad Architecture 2010 I would appreciate if someone could help me with this problem. The file and text i'm using is below. Thanks!
5 REPLIES 5
pendean
Nothing attached.
in reply to: pendean
Sorry, new at community 🙂
Ok.. problem with attachment..  Maybe now?
pendean
AutoCAD here reports missing shape fonts, specifically one called LV_TOPO_2012. Your 2010 file is also saved down to 2004, pre-2007 when fonts and things changed somewhat.
Also, why are you trying to oh-so-delicately rig MTEXT over a grided linework (aka a TABLE) instead of using TABLE command to do what appears to be, well, a table with text and entries? Curious method, good back in the DOS days of AutoCAD but unusual to see these days.
I set your MTEXT spacing to 350 (not 333.33335 that you had) and made a copy adjacent and changed it to 550. Closed the file, closed AutoCAD, opened the file, no settings changed. I did NOT save down to 2004.
Hi, pendean! Thank You for the reply! Saving to Autocad 2010 solved to problem 🙂 Although I work in Autocad for ~ 5 years now, I didn't learn table function yet. I guess I should give it a try!
”Boost
