AutoCAD Forum
Lookup Table Stuck In Read Only
3 REPLIES 3
888 Views, 3 Replies
Hi All,
I created a Look Up Table in AutoCAD 2014 Full version. I have no idea what I "bumped", but it's stuck in read only and I need someone to PLEASE tell me how to get it off. This is a huge table and I really can't do it again.
3 REPLIES 3
JoAnn_Hogan
Would you mind to please post your drawing here so I could have a look at it and see what went wrong.
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
dan
in reply to: JoAnn_Hogan
I am having the same issue with a lookup table. Was there ever a solution posted for this issue?
I attached my drawing - the malfunctioning block is ANDERSEN-DOUBLE-DOUBLEHUNG-ELEV.
Thanks, Dan Johnson
dan
in reply to: dan
I found the issue. I had initially entered all of my lookup values prefixed with (2) and then the window model. I didn't realize what that syntax meant. I then edited all of the lookups removing the "(2)" prefix but for some reason that didn't work so I had to re-enter all of the lookup values which did work. Laborious but at least I didn't have to re-enter all of the dimensions!
”Boost
