In browsing the internet, I came across a program call ‘Longbow Software’ which is supposed to allow earlier versions of AutoCAD (AutoCAD 2001 thru 2009) to install and run on Windows 8.1. Has anyone used this program?
If so, what is your experience and does it work?
I know that post was 3 years ago, but I go ahead and reply anyhow.
Yes, I own AutoCAD Architecture 2008 as latest version I have. And I installed Longbow Software for Windows 7, it worked perfectly. I also installed Longbow Software for Windows 10, it also worked perfectly!!! Awesome! I was so happy that I know that Longbow Software will be good forever because their testimony is that some of their customers are still using AutoCAD R13!!! That would be 1998 version of AutoCAD, almost 20 years ago!
All of sudden... I just learned that I could afford to lease AutoCAD Architecture 2017 for less than $215 instead of having to purchase $5000 AutoCAD software. Now I wonder will Longbow Software continue beyond 2017?
HI @Dhrd
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I don't personally have any experience with this product but @pendean seems to be a proponent of it as he as mentioned in many posts.
I know that there are a good number of customers that have used it but I am not aware of how well they felt it performed.
I did take a quick look and there seem to be quite a few support cases logged with this product. In my opinion, I would suggest running current product that is designed for your current operating system and drivers. This is likely to produce the least number of headaches and issues.
Either way, you might try it and report back with your findings in order to help other Community members.
Hi @Dhrd,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Dear Forum members.
Has anyone successfully run a very old version of Autocad, namely R14, on a windows 10 64 bit computer using Longbow software?
Ken
Pendean, I already have Draftsight, and don't like it.
I'm well and truly well versed with R14, but the main reason is I have my version heavily customised
Ken
Yup, tell me about it. I do have heavy customized, too. Hope it works. But my another suggestion is to upgrade Windows 10 to PRO version. They claim it can run a very old program like R14 on Windows 10 PRO. I will try that soon.
I have been using AutoCAD 2002 with Raster design R3 for quite some time now, (20 years) when I switched over to Win7 I was able to load both programs onto my latest computer, however there was no improvement in performance and occasionally there were unhandled errors which of course caused AutoCAD to crash. My experience has been that unhandled errors are usually due to AutoCad running out of memory or trying to use memory that is already in use. Using Long Bow reviver to reinstall AutoCAD 2002 on Win7 seems to have eliminated this problem by allow AutoCAD to use more available memory then before. Also AutoCAD runs considerably faster with redraws taking less time. It has also improved the performance of Raster design even though I did not use it to install that program. I would highly recommend using Long Bow software if you are trying to install older AutoDesk Software on a newer operating system like Win7 or newer.
I have successfully run version R14 through 2000 with Longbow on Windows 10 64 bit without issue. A remarkably stable product which does exactly what it claims to do. Best software product available to run older versions of CAD on new operating systems.
Currently running AutoCAD 2000 32 bit on Windows 10 64 bit
